[GRASS5] Re: [GRASSLIST:3624] Cell Resolution help
fa1079 at qmul.ac.uk fa1079 at qmul.ac.uk
Fri May 3 15:26:20 EDT 2002
I think the discussion is turning in circles a bit. Maybe by focussing on the different seperate issues, we can advance:
1) Grass is not very intuitive in its structure and so newbies find it difficult. One main difficulty is the lack of documentation. This is currently being worked on, I will begin revising the turorial within the next few days, once life outside Grass leaves me some time. There is an enthousiastic (albeit also limited) team ready to work on this, but any more help is welcome. One of the first steps should probably be a FAQ. Feedback from Baylor might help in this.
2) The region is a difficult concept in Grass. It is very helpful for a lot of the analysis work, but not very easy to grasp at the beginning. So, we should think about whether it would be feasible to implement some default region creation at start-up and some "region checking and warning" in some of the standard modules.
3) Should Grass implement "reasonable defaults" ? This means that we have to identify these defaults and see whether and where it makes sense to implement them.
All these are important questions and we should be grateful to Russell for raising them this forcefully. Maybe we won't be able to implement them for Grass5.0, but thinking about them for Grass5.1 is definitely worth it.
Moritz
On Fri, May 03, 2002 at 10:34:52AM -0400, Russell Nelson wrote:
> Does anyone want to further dispute my contention that region-setting
> is difficult and confusing?  See the following snippet from a posting
> on GRASSLIST today.
> -russ
> Anil Kumar Bhagat writes:
>  > Dear GRASS users
>  > [ snip ]
>  > My objective is to know how this cell resolution is related to
>  > LISS 3 data resolution ( 23.5 ) and during import what should be the
>  > grid resolution .
>  > Also want to know about the what should be the scaned toposheet map
>  > resolution .
> -russ nelson              http://russnelson.com | Okay, enough is enough!
> Crynwr sells support for free software  | PGPok | Can we PLEASE all stop
> 521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
> Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   | email products???
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
