[GRASS5] A naive opinion on how grass *should* work
Eric G. Miller
egm2 at jps.net
Fri May 3 21:34:04 EDT 2002
On Fri, May 03, 2002 at 03:35:50PM -0400, Russell Nelson wrote:
> And instead of whining (anymore) I'm going to start fixing. I first
> must figure out why merely compiling grass from CVS is killing my X
> server.
Poor cooling? Bad memory?
> > It is a recognized fact, that the region concept trips up people new to
> > GRASS.
> In my experience, when people commonly have trouble with something, it
> is the thing that is at fault, and should be repaired. I have a plan
> (defer region setting until it is absolutely necessary). If you don't
> like it, what's your plan?
I don't have any plan regarding regions. If you want to look at a
different way of handling region settings, you probably will want to
work with grass51, since such a change won't be accepted for 5.0.
Eric G. Miller <egm2 at jps.net>
