[GRASS5] documentation
Markus Neteler neteler at itc.it
Tue May 7 11:53:09 EDT 2002
On Tue, May 07, 2002 at 05:53:24PM +0200, Moritz Lennert wrote:
> Here's a proposition for a grass-doc repository for documentation:
> (thanks to Eric Lemesre <eric.lemesre at agf.fr>)
>  grass-doc
> 	/m4
>  	/doc
>  	/po
>  	/images
>  	/tools
>  	/src
>  		/fr
>  		/en
>  		/de
> The /src/LANG directories would contain the translation files of common doc plus any contributed doc that only exists in the respective language (in a /src/LANG/contrib directory)).
> The /doc directory will contain documentation about the documentation and how to write/use it.
> So, as an example, Russ's HOWTO (thank you Russ for having been declared volunteer ;-)) would go into /src/en.
> Does this look ok. Would it be possible to put it on the Intevation server ?
Hi Moritz,
the proposal looks reasonable to me.
If needed I have a script to check in the entire tree in one step into
CVS.
Ciao
 Markus
