[GRASS5] ANN: GRASS on iPAQ/Linux available
Bernhard Reiter bernhard at intevation.de
Wed May 8 05:54:17 EDT 2002
On Wed, May 08, 2002 at 01:33:14AM +0100, Glynn Clements wrote:
> Carl Worth wrote:
> > 	o All other files are in /usr/share/grass/,
> > 	(eg. /usr/share/grass/bin, /usr/share/grass/etc, etc.)  This
> > 	layout matches standard (FHS) practice and is cleaner than
> > 	installing directories such as
> > 	dist.armv4l-unknown-linux-gnu. Perhaps I should change it to
> > 	/usr/share/grass5 though?
> /usr/share is supposed to be for files which are shareable across
> architectures, i.e. not executables or libraries. I suggest using
> /opt.
I agree as /opt also fits FHS and suites GRASS better.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020508/8f0a0b2c/attachment.bin
