[GRASS5] Re: [GRASS-CVS] CVS update: grass/src/mapdev/v.llabel
Radim Blazek blazek at itc.it
Thu May 9 10:33:18 EDT 2002
Fixed now (I hope), in both (I hope).
Radim
On Thursday 09 May 2002 03:53 pm, Bernhard Reiter wrote:
> On Thu, May 09, 2002 at 05:02:48AM -0600, Roger Miller wrote:
> > On Thursday 09 May 2002 01:11, Radim wrote:
> > > Sorry Roger, I don't want to discourage you, to contribute to grass,
> > > but module should be probably run, before changes are commited,
> > I thought I made it clear to the list that I was currently unable to test
> > the change, but I was encouraged to commit the change anyway.  After all,
> > the code was broken to start with and committing still broken code didn't
> > make anything worse and had a chance of helping.
> Yes, this was okay.
> Radim: I told Roger to commit this as the code was broken anyway.
> Thus I'm the one to critise here, because Roger asked first.
> I still think it was correct, as it was the only chance for Roger to
> help us. He just should have committed the same fix to HEAD.
> > > and that all fixes in release branch MUST be commited to HEAD, is
> > > obvious (I hope, am I right?
> Yes, you are right.
> > I committed it to the release branch because discussion on this list lead
> > me to believe the release branch would be merged back into HEAD after the
> > release was made.  If we can work only on release-critical bugs and we
> > have to commit to both branches then the release branch would seem to be
> > superfluous.
> Making sure that each change is made in the release branch
> and in HEAD, is like merging each change in a way.
> We need the release branch, because HEAD is more advanced.
> So the fix for the Release branch might not be the same for the HEAD
> branch. You can work on other bugs and smaller enhancement on HEAD.
Content-Type: application/pgp-signature; charset="us-ascii";
name="Attachment: 1"
Content-Transfer-Encoding: 7bit
Content-Description:
