[GRASS5] Tarball?!!
Markus Neteler neteler at itc.it
Fri May 10 02:51:12 EDT 2002
On Fri, May 10, 2002 at 06:02:33AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > any objections for creating the source tarball of the release branch?
> > If not, I'll do that tomorrow morning Italian/Central European time.
> We should check whether any of the recent changes should be
> incorporated into the release. A complete list of the differences
> between the head and the release branch follows.
[snip]
> src/raster/r.what/
> 	Increase NFILES
there was a limit to 14 files. I have tested with 110 files without
problems.
> 	Fix potential compile error (trailing garbage)
It seems that especially iPAQ-gcc is very sensitive to compiler warnings
while Linux/iX86 happily continues. It's a fix.
[...no comment]
> src/display/devices/windows
> 	Use gmake5
> 	Various fixes
If the fix re-enables winGRASS, we should consider a sync.
[...no comment]
> src.contrib/GMSL/NVIZ2.2/src/tkInt8.0p2.h
> src.contrib/GMSL/NVIZ2.2/src/tkInt8.0.2.h
> src.contrib/GMSL/NVIZ2.2/src/tkInt8.0.5.h
> src.contrib/GMSL/NVIZ2.2/src/togl.c
> 	Add tkInt8.0.5.h
This should be also in release
> src.contrib/GMSL/NVIZ2.2/scripts/nviz2.2_script
> src.contrib/GMSL/NVIZ2.2/src/nviz_init.c
> 	Load state file ("state=") option
Did anyone test that except me? Here it works well and
does not look like a dangerous change.
> html/html/m.in.e00.html
> 	Document -t switch
> 	Additional comments regarding raster (GRID) files
Should be sync'ed.
> html/html/d.extend.html
> 	Change format of Huidae's email address
Should be sync'ed.
> mk/Makefile.docs
> 	Fix bug in generating manpages
Should be sync'ed.
> handheld/
> 	Added
Should be sync'ed (just to scripts).
Markus
