[GRASS5] Tarball?!!
Mike Thomas mthomas at gil.com.au
Fri May 10 22:30:32 EDT 2002
Hi all.
> > src/display/devices/windows
> > Use gmake5
> > Various fixes
> However, I've just discovered that Mike reverted the Makefiles,
> apparently due to a problem with the Gmakefiles. I'd like to see what
> the issue is before progressing.
Minor problem - see separate message on WinGrass list.
The interesting aspect of this problem is that there were no Gmakefiles per
se in the Pre4 branch apart from the original one in
"src/display/devices/windows" which drove the original Cygwin Makefiles in
"wrap" and "w32" (which seems to be a  reasonable state of affairs given
that the Cygwin Makefiles work).
For some reason or other those subdirectory Gmakefiles only appeared in the
CVS Head.
Cheers
Mike Thomas
