[GRASS5] NVIZ Tk8.0 on Debian
Glynn Clements glynn.clements at virgin.net
Mon May 13 04:38:30 EDT 2002
Glynn Clements wrote:
> If you send me the tkInt.h for 8.0p5, I'll add it to NVIZ' collection
> of tkInt.h files.
Unfortunately, it appears that this header isn't compatible with Tk
8.0p5. The header references the type Tk_SmoothMethod, which
(according to Tk's ChangeLog) was added on 1999-12-13, but 8.0p5 was
released on 1999-03-09. So, this appears to be a Debian-ism.
I'll revert the changes.
Ultimately, configure should check for a local tkInt.h file before
attempting to use any of the supplied version. However, that
presumably won't make it into pre4.
Glynn Clements <glynn.clements at virgin.net>
