[GRASS5] Re: [GRASS-CVS] bernhard: grass SUBMITTING,1.21,1.22
Markus Neteler neteler at itc.it
Tue May 14 02:33:20 EDT 2002
On Mon, May 13, 2002 at 09:04:07PM +0200, Bernhard Reiter wrote:
> As you can see a slightly adapted version of syncmail
> (http://sourceforge.net/projects/cvs-syncmail/)
> is running on the GRASS cvs server now.
Congrats, Bernhard! Now the author is back in the mail, fine.
> It only generates emails for the modules web and grass right now.
> Do you want commit messages for all modules?
I don't think so - if you are open to add it later in case we
need it.
> On the topic above: I still believe that we should put ID
> tags in files. The statement that this makes problems with
> branches does not seem to be completly correct.
Glynn was complaining here - he may decide.
> 	Bernhard
> On Mon, May 13, 2002 at 08:42:36PM +0200, grass at intevation.de wrote:
> > Author: bernhard
> > Update of /grassrepository/grass
> > In directory doto:/tmp/cvs-serv8822
> > Modified Files:
> > 	SUBMITTING
> > Log Message:
> > SUBMITTING: added a "(?)" because the rule seems strange and I
> > 		want to test the new syncmail.
> > Index: SUBMITTING
> > RCS file: /grassrepository/grass/SUBMITTING,v
> > retrieving revision 1.21
> > retrieving revision 1.22
> > diff -u -d -r1.21 -r1.22
> > --- SUBMITTING	6 Mar 2002 16:24:49 -0000	1.21
> > +++ SUBMITTING	13 May 2002 18:42:34 -0000	1.22
> > @@ -55,7 +55,7 @@
> >      The copyright protects your rights according to GNU General Public
> >      License (www.gnu.org).
> > -4.  - deleted. We don't want the $ ID $ in source code any more as it
> > +4.  - deleted.(?) We don't want the $ ID $ in source code any more as it
> >      causes problems for the CVS branches.
> >  5.  To ensure that the software system continues to work, please include
