[GRASS5] Re: [GRASS-CVS] markus: grass Makefile.in,1.94,1.95
Markus Neteler
neteler at itc.it
Wed May 15 07:08:05 EDT 2002
On Wed, May 15, 2002 at 03:16:45AM -0700, Alex Shevlakov wrote:
> Hi Markus,
> seems to me this is excessive to create "locale"
> directory if it was missing (actually, it would always
> be missing). tar xBf would copy the entire "locale"
> directory to $INST_DIR in case it happened to occur in
> $GISBASE after gmake5 works in src/locale. This was
> tested more then once.
Hi Alex,
here the tar command crashed... maybe this function is not
fully portable?
test -d /usr/local/src/grass5.0.0pre4/dist.i686-pc-linux-gnu/locale &&
/bin/sh -c "cd /usr/local/src/grass5.0.0pre4/dist.i686-pc-linux-gnu ;
tar cBf - locale | (cd /usr/local/grass5 ; tar xBf - ) 2>/dev/null ;
true"
make[1]: *** [real-install] Error 1
make[1]: Leaving directory /usr/local/src/grass5.0.0pre4'
make: *** [install] Error 2
That's why I was adding it.
Markus
> --alex
> --- grass at intevation.de wrote:
> > Author: markus
> > Update of /grassrepository/grass
> > In directory doto:/tmp/cvs-serv2512
> > Modified Files:
> > Makefile.in
> > Log Message:
> > bugfix for creating locale directory in INST_DIR -
> > was missing
> > Index: Makefile.in
> > RCS file: /grassrepository/grass/Makefile.in,v
> > retrieving revision 1.94
> > retrieving revision 1.95
> > diff -u -d -r1.94 -r1.95
> > --- Makefile.in 10 May 2002 12:46:33 -0000 1.94
> > +++ Makefile.in 15 May 2002 08:30:55 -0000 1.95
> > @@ -184,6 +184,7 @@
> > ${SHELL} -c "cd ${GISBASE} ; tar cBf - scripts |
> > (cd ${INST_DIR} ; tar xBf - ) 2>/dev/null ; true"
> > ${SHELL} -c "cd ${GISBASE} ; tar cBf - tcltkgrass
> > ${SHELL} -c "cd ${GISBASE} ; tar cBf - txt | (cd
> > + test -d ${GISBASE}/locale && test -d
> > ${INST_DIR}/locale || ${MAKE_DIR_CMD}
> > ${INST_DIR}/locale
> > test -d ${GISBASE}/locale && ${SHELL} -c "cd
> > ${GISBASE} ; tar cBf - locale | (cd ${INST_DIR} ;
> > @ # The man, include, and lib could go to
> > ${PREFIX}/ BUT if this is
> > @ # done, then the corresponding uninstall
> > instructions must delete
> > grass-commit mailing list
> > grass-commit at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-commit
> __________________________________________________
> Do You Yahoo!?
> LAUNCH - Your Yahoo! Music Experience
> http://launch.yahoo.com
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
