[GRASS5] [bug #1045] (grass) New r.mapcalc bug in G5pre4
Glynn Clements
glynn.clements at virgin.net
Wed May 15 10:47:21 EDT 2002
Helena wrote:
> This looks like a similar problem that we have with the new r.mapcalc
> - in our case the problem was spaces. It appears that the new
> r.mapcalc has some changes in how it interprets the expression which
> is breaking old scripts - I think that it should be fixed
I can only fix bugs which are reported.
The only intentional changes from the original r.mapcalc are that the
type inference is more conservative, and that floating-point values
are no longer acceptable where a boolean value is expected.
Any other difference is probably a bug, and will be fixed if
reported.
> (or reverted to pre3 version?- what else is different compared to
> pre3?
The current version is a complete re-write.
Glynn Clements <glynn.clements at virgin.net>
