[GRASS5] [bug #1047] (grass) suggestion to solve r.proj initialization problem
Morten Hulden morten at ngb.se
Fri May 17 08:10:53 EDT 2002
> My suggestion is to apply  the function
> char * G_tolcase (string)
> somewhere in
> key_value2.c called by
>  src/libes/gis/get_projinfo.c
> to generally resolve that problem.
> Markus
This is a special case where the GRASS ellipsoid name differs from proj's
ellipsoid name _only_ by case. There are other cases where the names are
completely different. Would not a long-term solution better have common
list of ellipsoid names?
Morten Hulden
