[GRASS5] Re: [GRASS-CVS] frankw: grass/src/raster/r.in.gdal main.c,1.13,1.13.2.1
Bernhard Reiter bernhard at intevation.de
Fri May 17 09:53:04 EDT 2002
On Fri, May 17, 2002 at 03:37:06PM +0200, grass at intevation.de wrote:
> Author: frankw
> Update of /grassrepository/grass/src/raster/r.in.gdal
> In directory doto:/tmp/cvs-serv7101
> Modified Files:
>       Tag: releasebranch_26_april_2002_5_0_0
> 	main.c
> Log Message:
> convert ellps value to lower case per RT bug 1047
Is this really release critical bug?
IMO it looks more like it should be only into HEAD.
> +        /* All the ellipsoid keys in GRASS are lower case.  Eventually we
> +           may need to remove this hack.  See bug 1047 in RT bug tracker. */
> +        if( G_strcasecmp(pszToken,"ellps") == 0 )
> +            G_tolcase( pszValue );
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020517/27831e1d/attachment.bin
