[GRASS5] Re: [GRASS-CVS] frankw: grass/src/raster/r.in.gdal main.c,1.13,1.13.2.1
Bernhard Reiter bernhard at intevation.de
Fri May 17 10:04:37 EDT 2002
On Fri, May 17, 2002 at 03:58:06PM +0200, Markus Neteler wrote:
> > > Update of /grassrepository/grass/src/raster/r.in.gdal
> > > In directory doto:/tmp/cvs-serv7101
> > > Modified Files:
> > >       Tag: releasebranch_26_april_2002_5_0_0
> > > 	main.c
> > > Log Message:
> > > convert ellps value to lower case per RT bug 1047
> This fix should be both in HEAD and releasebranch_26_april_2002_5_0_0.
Frank, can you also commit the fix to HEAD?
Thanks.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020517/5e849a27/attachment.bin
