[GRASS5] Re: [GRASS-CVS] frankw: grass/src/raster/r.in.gdal main.c,1.13,1.13.2.1
Bernhard Reiter bernhard at intevation.de
Fri May 17 11:51:57 EDT 2002
On Fri, May 17, 2002 at 04:30:10PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > This fix should be both in HEAD and releasebranch_26_april_2002_5_0_0.
> Now that pre4 has been released, all fixes should go into HEAD. That
> will make it easier to merge such changes for pre5.
No, this is not our strategy.
We want a _tested_ release.  Pre4 is a release candidat.
Unless some serious reasons come up,
there will be no pre5, but a 5.0.0 of that branch.
Please only fix release critical bugs!
And fix them on both the release branch and HEAD.
Glynn: You also had one fix which only went into the release branch, please
also merge it into the HEAD.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020517/3fb84a11/attachment.bin
