[GRASS5] Re: [GRASS-CVS] frankw: grass/src/raster/r.in.gdal main.c,1.13,1.13.2.1
Bernhard Reiter bernhard at intevation.de
Fri May 17 15:50:33 EDT 2002
On Fri, May 17, 2002 at 03:10:31PM -0400, Frank Warmerdam wrote:
> Bernhard Reiter wrote:
> >No, this is not our strategy.
> >We want a _tested_ release.  Pre4 is a release candidat.
> >Unless some serious reasons come up,
> >there will be no pre5, but a 5.0.0 of that branch.
> >Please only fix release critical bugs!
> >And fix them on both the release branch and HEAD.
> Bernhard,
> I assume you mean only fix release critical bugs in the release branch,
> right?
Yes.
> Non critical bugs can still be fixed in the HEAD for 5.0.x point releases
> right?
Correct.
> I have removed by patch from the release branch, and successfully applied it
> to the head.
Thanks!
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020517/56526f7a/attachment.bin
