[GRASS5] [Fwd: [GRASSLIST:3732] RE: Grass 5.0.0pre4 RPMs for Mandrake 8.2]
Buchan Milne bgmilne at cae.co.za
Mon May 27 10:22:16 EDT 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Bernhard Reiter wrote:
|>Hash: SHA1
|>OK, I was told this mail would be more appropriate for the devel list
|>than the grasslist, so here goes ...
|>In case you are missing the context, I have put grass 5.0pre3 RPMs into
|>the Mandrake Cooker, and am busy with pre4 RPMs, which can be found at:
|>http://ranger.dnsalias.com/mandrake/mandrake8.2/grass/
| Have you compared them to the RPMs from the FreeGIS CD?
| It'*s probably fine to have more than one spec file.
I have looked at the spec file in the grass source (under rpmspecs), but
there were quite a few things that needed to be changed for inclusion in
Mandrake, and olny 160 of 3800 lines weren't %files lists (which I hope
to be able to do with %files -f <filename> and some sed/grep).
I have some experience building RPMs on multiple releases of Mandrake (I
help maintain samba for Mandrake) with optional features, and I would be
prepared to help getting one SPEC file that builds correctly (both in
terms of functionality and and compliance with building standards for
the distro). The patch mentioned would be a good first step in that
direction, IMHO.
Regards,
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE88kEYrJK6UGDSBKcRAuQEAJ9/HapcQdK8YjrpANylJToNtBwNigCfXZUd
5AZ4G4dEzPFzgb/P9i9Q+WI=
=zIMj
-----END PGP SIGNATURE-----
