[GRASS5] Re: [GRASSLIST:5080] Re: r3out.v5d(?) problem
John Harrop johnh at sjgeophysics.com
Tue Nov 26 18:08:14 EST 2002
Markus, Eric and Jaro:
I moved this thread to the dev list since it seems to be heading that
way ;-)
Thanks for your responses.  Our group is most interested in the 3D
volumetric and vector support and since we need to test for internally
written code I think we can probably help with testing.   I'll take a
look at the current CVS and re-read the programmers manual.  I've been
looking at source navigator and considering using it  - anyone else
tried it or have other comments?
Is the row-col problem specifically described anywhere?  Or is it just
as fast to browse the source?
Cheers,
John Harrop
Markus Neteler wrote:
>Hi John,
>the CVS code of GRASS 5.0.1 (to be released hopefully soon) contains
>some fixes for the G3D from Alfonso Vitti (Univ. Trento) which
>overcome a set of problems. AFAIK there is still a problem with
>rows and cols not equal.
>If you are able to compile GRASS 5.0.0, you may try the CVS version
>or CVS snapshot. We definitly need 1 or 2 people to look again into
>G3D and test the modules.
>Best regards
> Markus Neteler
