[GRASS5] Re: [GRASS-CVS] eric: grass/src/mapdev/v.out.shape extract.c,1.8,1.9
Eric G. Miller egm2 at jps.net
Fri Oct 4 11:35:16 EDT 2002
On Fri, Oct 04, 2002 at 09:58:52AM +0200, Markus Neteler wrote:
> Hi Eric,
> thanks for fixing the memory corruption bug: now commands like
> v.out.shape areamap type=area
> do no longer crash. But... :-)
> If the map contains islands, they are still filled by the surrounding
> area.
> If ever possible, maybe somebody could look into that (or I
> am missing something, probably islands in SHAPE are a problem?
> Note that I checked the SHAPE file with Arcexplorer for Linux,
> maybe the problem is there).
Islands are presumably holes and need to have their direction reversed.
Shapefiles use a winding rule to determine interior/exterior boundaries.
begin 664 .signature
M<F5L;&E-("Y'(&-I<D4@/G1E;BYS<&I`,FUG93P)"`@("`@("`@("`@("`@(
M"`@("`@("`@("`@("`@("`A%<FEC($<N($UI;&QE<B`\96=M,D!J<',N;F5T
"/@H`
end
