[GRASS5] Code formatting style
Glynn Clements glynn.clements at virgin.net
Fri Oct 11 16:08:35 EDT 2002
Bernhard Reiter wrote:
> I agree that a common code style is important.
> My point was that automatic reformatting has to be followed
> by human inspection.
Why? indent understands enough of C not to change the semantics of the
code. Outside of string literals and preprocessor directives, all
whitespace is equal.
> If there is no human inspection I'd not
> recommend a massive automatic reformatting.
> Thus when you actually do development you can do the reformatting.
> Also possible as preprocessing step for automatic clone detection.  :)
> We could look into the GNU coding styles...
indent understands the GNU, K&R, and Berkely predefined styles;
these are documented in the indent manpage.
More generally, I do think that the reformatting should be done
"aggressively", i.e. wherever you have a choice of "--foo" or
"--no-foo", you should choose one of them.
Glynn Clements <glynn.clements at virgin.net>
