[GRASS5] gis lib: write error function (put_row.c)
Gordon Keith gordon.keith at csiro.au
Tue Oct 22 18:04:16 EDT 2002
On Tue, 22 Oct 2002 18:25, Markus Neteler wrote:
> Hi,
> while having the problem that a disk run out of space
> while using r.in.gdal, I found that
> write_error()
> in src/libes/gis/put_row.c
> just contains G_warning() and not G_fatal_error().
> Are there objections to change this to
> G_fatal_error("...unable to write row...")
> It doesn't make much sense to continue writing to a full disk.
BUT, you can't clean up after G_fatal_error.
If you run out of disk space the first thing you want to do is delete
temporary raster files. If you call G_fatal_error the temporary file is
left in place, aggrevating the problem.
(Did I mention I had problems with a script that had a faulty region
setting and the whole thing failed because s.to.rast called
G_fatal_error when it failed to write a row and left a 2GB file in the
.tmp directory. After a few attempts at this my disk was full and the
script was failing because there wasn't any disk space.)
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
The main thing is to keep the main thing the main thing.
