[GRASS5] [bug #1362] (grass) v.out.shape only can export labeled polygones
Eric G. Miller egm2 at jps.net
Wed Oct 23 11:05:19 EDT 2002
On Wed, Oct 23, 2002 at 10:16:30AM +0200, Radim Blazek wrote:
> On Wednesday 23 October 2002 09:39 am, Silke Reimer wrote:
> > Would it be difficult to improve v.out.shape so that it can export
> > non labeled polygons from GRASS? The problem is that we have about
> > 300 polygons in one layer and it would be very exhausting to label
> > all those polygons. Any suggestions?
> If I remember it well, v.out.shape worked in that way, but some other
> user :) wanted export of labeled areas only, so it was changed.
> We need new flag for that to do it optionaly.
Some other user wanted it to work with polygons period.  I set it to
only export labelled areas because it is the only way to differentiate
islands from holes.  It would be possible to modify it to output all
areas.
static const char signature[] =
	"Copyright (c) 2002 Eric G. Miller <egm2 at jps.net>";
