[GRASS5] GRASS 5.0.0 to be released now
Buchan Milne bgmilne at cae.co.za
Wed Sep 4 07:31:59 EDT 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Markus Neteler wrote:
| Dear developers,
| Glynn Clements has tagged "release_30_08_2002_grass5_0_0" for
| us, at time the packaging of GRASS 5.0.0 is running (source code
| and GNU/Linux-x86 binaries) here.
| Tomorrow morning (Central European time) we should have
| the stable GRASS 5.0.0 release in our hands!
Is it too late to fix the source tarall?
It doesn't have a top directory (grass5.0.0) which all the pre-releases had.
To stick with standard packaging, it should actually be grass-5.0.0 (so
that the RPM default %prep works, which uses %name-%version), and the
source tarball should actually be grass-5.0.0.tar.gz (or, I guess you
could do grass-5.0.0_src.tar.gz), instead of the current
grass5.0.0_src.tar.gz.
Otherwise, I am going to have to hack the %prep section , and probably
return it like it was later.
Regards,
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x121
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE9de8vrJK6UGDSBKcRAjASAKCt547Kyc/9ErQN/bKFtyh1YAz30ACfWOOM
um9kQ9vFoBarBYsrgYIKzYQ=
=8Xve
-----END PGP SIGNATURE-----
