[GRASS5] points in interior or inside shape
Michael Ash mash at econs.umass.edu
Fri Sep 27 09:55:05 EDT 2002
I want to assign each of a set of points (now a site layer) to the
geographic area (Census tract) in which it resides.
I have a vector layer converted with m.in.e00 and v.support from a .e00
U.S. Census cartographic boundary file.  So I think that the unit of
observation is the polygon.
I have a site layer.
Both layers are in the same region, projection, etc.  If I display both,
I can see the sites overlaid on the shapes.
How do I establish "interiority"?  That is, I think that I would like to
generate a new site layer that assign to each site the identifier of the
polygon it is inside.
I would welcome any advice that you can offer.  I have considered
converting the vector layer to raster and using s.sample or converting
both to raster and using r.mapcalc.  Is there a better approach?
Best regards,
Michael Ash
Assistant Professor of Economics
and Public Policy
UMass-Amherst
