[GRASS5] [bug #1797] (grass) g.gisenv
Glynn Clements glynn.clements at virgin.net
Sat Apr 12 05:58:42 EDT 2003
Request Tracker wrote:
> Subject: g.gisenv
> g.gisenv lets you set a variable to nonexistant values without a check, and
> the only way to go on is to exit GRASS and delete/edit the .grassrc5 file.
> e.g., (user1 exists, usr1 doesn't)
> GRASS:~ > g.gisenv MAPSET
> user1
> GRASS:~ > g.gisenv set="MAPSET=usr1"
> GRASS:~ >
> GRASS:~ > g.gisenv
> ERROR: MAPSET usr1 not found
> GRASS:~ >
> GRASS:~ > g.gisenv set="MAPSET=user1"
> GRASS:~ > exit
> I had a try using G_getenv to make a backup copy of the old value before
> attempting to G_setenv, and then test G_getenv for success, but as G_getenv
> fails with an exit, I can't set it back to the original if it fails..
> When you try to fix it later with another set= to a real value, it fails (and
> G_fatal_error's) again before it can set the new value.
> any ideas?
g.gisenv calls G_gisinit(), which generates a fatal error if the
mapset directory doesn't exist or has incorrect permissions (i.e.
ownership).
Using:
	G_set_program_name(argv[0]);
	G_no_gisinit();
should work.
Glynn Clements <glynn.clements at virgin.net>
