[GRASS5] g3d and v.in.mif changes
Bernhard Reiter bernhard at intevation.de
Fri Aug 8 05:06:33 EDT 2003
John,
if you had some fixes for v.in.mif,
it would be interesting to have them,
because as of today it seems still broken.
Can you publish them somewhere of if they are very short,
just post them to this list.
Thanks,
	Bernhard
On Wed, Feb 26, 2003 at 01:57:10PM -0800, John Harrop wrote:
> This last week I've been re-syncing with the latest source to get back
> to working on testing and fixing.  As I was reading through this list I
> noticed HM and GC had been asking about some of the changes and testing.
> Couple of comments:
> 3) We needed to import some MapInfo mif files and so I've tested and
> fixed some of the problems in v.in.mif.  The import is working and we
> are using it, but I have one more bug I need to track down before I
> sumbit fixes.  The changes are small and minor but the errors resulted
> in bad file names and seg faults.
> Glynn:  shall I send them to you as diffs the way I did before?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030808/ab2259d2/attachment.bin
