[GRASS5] r.in.gdal compile problem
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Aug 9 05:37:59 EDT 2003
Hello
William K wrote:
> With GRASS 5.0.3 CVS (7-19 and a couple earlier versions) I can't get
> r.in.gdal to compile.  I get an illegal indirect reference from libgis
> to libgrass:
> gcc
> -L/Users/williamk/Documents/src/unix/GRASS/grass50_exp_2003_06_28/src/
> libes/LIB.powerpc-apple-darwin6.6  -o
> dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.in.gdal
> OBJ.powerpc-apple-darwin6.6/main.o
> OBJ.powerpc-apple-darwin6.6/gbgetsymbol.o
> OBJ.powerpc-apple-darwin6.6/gdalbridge.o
> OBJ.powerpc-apple-darwin6.6/make_loc.o \
>          -L/usr/local/lib -lgdal.1.1 -lgeotiff -ltiff -lgproj
> -L/usr/local/lib -lproj  -lgis  -lintl -lI  -lz
> ld:
> libes/LIB.powerpc-apple-darwin6.6/libgis.a(color_rule.o) illegal
> reference to symbol: _G__color_free_fp_lookup defined in indirectly
> referenced dynamic library /usr/local/lib/libgrass5.0.dylib
It looks like you have GDAL compiled with external GRASS support and it
is looking in the libgrass5 library. Looks like that can get a bit
complicated if you are using GDAL directly with GRASS, so maybe try
compiling GDAL without this (--with-grass=no as a configure script
option---but this should be the default).
> ld: warning multiple definitions of symbol _CSVGetFileFieldId
> /usr/local/lib/libgdal.1.1.dylib(cpl_csv.o) definition of
> _CSVGetFileFieldId
> /usr/local/lib/libgeotiff.dylib(cpl_csv.o) definition of
> _CSVGetFileFieldId
I can only suggest to not use an external tiff library when compiling
GDAL and use the GDAL internal tiff (--with-libtiff=internal
--with-geotiff=internal or something similar). I think I read somewhere
there are problems using external tiff libraries with GDAL?
I'm not sure if this is the best way to fix the problems but it might be
a workaround.
Paul
> make[1]: ***
> [/Users/williamk/Documents/src/unix/GRASS/grass50_exp_2003_06_28/
> dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.in.gdal] Error 1
> GISGEN failure at STEP: src/raster/r.in.gdal
> I've tried reordering the LIBES libs, and GDAL_LIBS & LIBES, in the
> GMakefile for r.in.gdal, but that just causes other indirect
> references.  This is beyond my porting experience so far to know what
> it means and how to fix it.
> William Kyngesburye <kyngchaos at charter.net>
> http://webpages.charter.net/kyngchaos/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
> RIP Douglas Adams 1952-2001
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
