[GRASS5] Let's publish 5.0.3
Markus Neteler neteler at itc.it
Mon Aug 11 07:28:56 EDT 2003
On Mon, Aug 11, 2003 at 12:10:05PM +0200, Bernhard Reiter wrote:
> On Sat, Aug 09, 2003 at 08:32:04AM +0200, Markus Neteler wrote:
> > > BTW, why the large gap between 5.3 and 5.7? What about 5.5? What will
> > > the stable releases be? 5.4 and?
> > Please have a look at the roadmap. If unclear, we should improve the
> > document
> We should include planned unstable (odd number) releases.
You mean 5.3.1 etc? Yes.
> >(yes, 5.4 will be the last stable version of the 5.x line):
> > http://grass.itc.it/roadmap.html
> According to the document that would be 5.8.x
> unless you've meant 5.0.x. :)
> Actually I'm against planing for 6.x as 5.10 will follow 5.9.x releases.
No, this won't be a good idea. The new vector engine is definitly
a major change, so 6.x is appropriate.
But maybe 5.7 should be named 5.5 to be consequent. However, then
it is far from number 6.
Markus
