[GRASS5] v.out.ascii truncation
Mon Aug 11 08:56:39 EDT 2003
> With the talk of publishing a stable 5.0.3, maybe someone can fix a
> v.out.ascii truncation bug I've been working around in 5.0.2.
> The problem, apparently in G_format_easting although I have not looked
> at that code, causes v.out.ascii in some cases to print out fewer
> significant digits for longitude than latitude.  Below is a portion of
> v.out.ascii output showing latitude is given six fractional digits but
> longitude only five.  Having six fractional digits (i.e., "%.6f") for
> both longitude and latitude is necessary
> Maybe there is a similar problem in G_format_northing that occurs for
> southern hemisphere latitudes.
ok, here you go (5.0.3CVS),  v.out.ascii output:
ZONE:         0
WEST EDGE:    166.25922773
EAST EDGE:    168.73890751
SOUTH EDGE:   -47.33126239
NORTH EDGE:   -44.17953637
MAP THRESH:   0
VERTI:
A  84946
 -46.22802974 167.02094088
 -46.22801981 167.02092309
 -46.22800988 167.02090529
 -46.22795726 167.02081077
 -46.22786854 167.0205745
 -46.2277771  167.02021374
 -46.22761506 167.01979546
 -46.22745475 167.01923402
Are you sure your input data isn't rounded at 5 sig.fig.?
v.to.sites -a
d.what.sites
g.region -p
> WEST EDGE:    -79.26619
> EAST EDGE:    -79.08578
> SOUTH EDGE:   37.340556
> NORTH EDGE:   37.469409
> MAP THRESH:   0
> VERTI:
> A  2
>  37.444541    -79.16844
>  37.448141    -79.17404
> A  11
>  37.448141    -79.17404
>  37.448963    -79.17539
>  37.449241    -79.17584
>  37.453221    -79.17876
>  37.453741    -79.17914
>  37.458141    -79.18474
>  37.458477    -79.18525
>  37.458893    -79.18563
>  37.459341    -79.18582
>  37.459661    -79.18592
>  37.460845    -79.18638
