[GRASS5] Let's publish 5.0.3
Bernhard Reiter bernhard at intevation.de
Mon Aug 11 11:15:14 EDT 2003
On Mon, Aug 11, 2003 at 12:41:42PM +0200, "Fernández-Victorio Arévalo, Gonzalo" wrote:
> > -----Mensaje original-----
> > De: Bernhard Reiter
> > Enviado el: lunes, 11 de agosto de 2003 12:10
> > Para: grass5 developers list
> > Asunto: Re: [GRASS5] Let's publish 5.0.3
> > >(yes, 5.4 will be the last stable version of the 5.x line):
> > > http://grass.itc.it/roadmap.html
> > According to the document that would be 5.8.x
> > unless you've meant 5.0.x. :)
> 5.8 is first stable version of the 6.x development line.
> The numbering could be strange, but the document seems rather
> clear. Hence the jump from 5.4 to 5.8.
Actually 5.8 is what was planned as 5.1.x and 5.2.x stable
releases so that is the 6.x development line this is confused. :)
> > Actually I'm against planing for 6.x as 5.10 will follow
> > 5.9.x releases.
Let's say: "Might".
> Radim's changes seems to be enough radical to mean a major
> version swift, but maybe I'm wrong.
No doubt that his improvements are major.
This is only about a clear numbering issue.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030811/80f9bbca/attachment.bin
