[GRASS5] [bug #2059] (grass) fix gdal lib check for Mac OS X
Paul Kelly via RT grass-bugs at intevation.de
Wed Aug 13 09:56:14 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2059
Request number 2059 was commented on by 'pkelly' (Paul Kelly).
Responding to this message will send mail to the requestor.
			Request Tracker
			rt at intevation.de
Cc: grass5 at grass.itc.it
A few comments (none of them the definitive answer):
1) gdalbridge is not really part of GRASS, but of GDAL; only a copy of it is
included in GRASS
2) If you compile with the --with-gdal option to the configure script,
gdalbridge should not be used---did you get an error or were you just looking
though the source code?
3) gdalbridge will probably be removed in the future as it seems to be a bit
unreliable and already in GRASS 5.7.x --with-gdal is a default option
-------------------------------------------- Managed by Request Tracker
