[GRASS5] [bug #2061] (grass) r.los needs FP update
Markus Neteler neteler at itc.it
Thu Aug 14 06:15:20 EDT 2003
On Wed, Aug 13, 2003 at 04:27:52PM +0100, Glynn Clements wrote:
> Request Tracker wrote:
> > Subject: r.los needs FP update
> > grass binary for platform: Compiled from Sources
> > After inspection of the source code (due to unsatisfying results)
> > it seems that 'r.los' only works with CELL elevation data:
> > src/raster/r.los/cmd/main.c:
> >          /*  allocate buffer space for row-io to layer           */
> >          cell = G_allocate_cell_buf();
> >          /*      open elevation overlay file for reading         */
> >          old = G_open_cell_old (elev_layer, old_mapset);
> > etc.
> > The module should be fixed to also accept FCELL/DCELL DEMs.
> > However, I have no clear idea how much work is needed for
> > that as segmentation is used internally.
> It should probably be changed to just use either FCELL or DCELL
> internally. I don't see any reason to preserve the underlying data
> type.
Sounds good - but the segment library (src/libes/segment/) seems
to be limited to CELL.
> AFAICT, the only situations where CELL maps shouldn't be converted to
> FP is where they may actually represent discrete categories rather
> than a scalar quantity.
Help is welcome to get r.los fixed.
Markus
