[GRASS5] [bug #2076] (grass) Same compilation error for modules: src/misc/m.kappa and src/raster/r.in.doq
Paul Kelly via RT grass-bugs at intevation.de
Mon Aug 25 08:08:53 EDT 2003
The r.in.doq bug was already fixed in CVS and will be in 5.0.3 anyway
I have fixed m.kappa now. The exit() function needed to have a number passed
to it. But this usage is not standard for GRASS anyway so I changed it to use
G_fatal_error() instead. Releasebranch changed also so this fix should make
it into the 5.0.3 release.
-------------------------------------------- Managed by Request Tracker
