[GRASS5] several questions on imagery commands
Glynn Clements glynn.clements at virgin.net
Mon Aug 25 21:01:30 EDT 2003
Moritz Lennert wrote:
> - Is there any significant difference between i.composite and r.composite ?
i.composite operates upon imagery groups; r.composite works on rasters.
i.composite has to be run interactively, r.composite can be scripted.
i.composite takes the intensity range (black/white values) from the
imagery files, r.composite uses the rasters' colour tables.
Other than that, both perform basically the same purpose.
Glynn Clements <glynn.clements at virgin.net>
