5.0.3 release candidate 1 - was: Re: [GRASS5] Roadmap: Numbering
Buchan Milne bgmilne at cae.co.za
Tue Aug 26 08:05:55 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Glynn Clements wrote:
> Markus Neteler wrote:
>>Concerning the readline support:
>>When adding -lncurses the test passes. Could be add -lncurses to
>>the config script (how) for the test?
> http://grass.itc.it/pipermail/grass5/2003-August/006104.html
The biggest problem is not that you need to specify additional ldflags
before configure, but that it isn't documented.
Would it not be possible to have
- --with-readline=(curses|ncurses|termcap|tinfo), and when it is not
specified, get the dependency information from libreadline?
In either case, the error message should mention that you need (to
specify) a library to use.
(Markus, yes, grass-5.0.2 also has this issue on Mandrake 9.0/9.1)
Regards,
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/S00jrJK6UGDSBKcRAuBKAKDNRZm2eo1Fi+6pPLW4yuJx3qxURACgvbKP
zMdWC/nDM9e2AIW1lOr2mho=
=In43
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info at cae.co.za for a copy.
