[GRASS5] color table
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Aug 27 07:25:55 EDT 2003
On Wed, 27 Aug 2003, Hamish wrote:
> > I'd like more time to look at the changes. Note that nobody has posted
> > a comprehensive summary of what's actually changed.
> How is this done?
> tools/diff.sh gives a list of changed files between two source files;
> cvs2cl.pl will give a changelog between two CVS tags, but as far as I
> can tell 5.0.2 and 5.0.3 share the same CVS tag, so it won't work.
> So how to make a cvs comments changelog between 5.0.2 and 5.0.3 with the
> same tag? Checking each filename in the CVS-web interface is too long a
> job for the many changes. Can cvs2cl.pl work by date+tag?
cvs2cl.pl -F releasebranch_26_april_2002_5_0_0 --delta \
release_10_04_2003_grass5_0_2:releasebranch_26_april_2002_5_0_0
seems to work (see below). I'm not sure it's that useful though; most
of the comments just say 'sync with HEAD' or something similar
Paul
2003-08-26 17:41  markus
	* AUTHORS: sync with HEAD
2003-08-26 08:03  markus
	* html/html/: shade.clr.sh.html, shade.rel.sh.html: sync'ed with
	  HEAD
2003-08-25 15:37  markus
	* src/libes/proj/doc/: OF90-284.pdf, PROJ.4.3.I2.pdf, PROJ.4.3.pdf,
	  SWISS.pdf, wwwlinks.txt: removed large files OF90-284.pdf
	  PROJ.4.3.I2.pdf PROJ.4.3.pdf SWISS.pdf (available from
	  http://www.remotesensing.org/proj/
2003-08-25 14:48  markus
	* NEWS.html: added shade.cls.sh fix from Hamish
2003-08-25 14:12  markus
	* src/scripts/shells/shade.clr.sh: sync'ed from HEAD
2003-08-25 13:07  paul
	* src/misc/m.kappa/cmd/prt_hdr.c: Fix bug 2076 (reported by Stefano
	  Perona)
2003-08-25 12:39  markus
	* src.garden/grass.postgresql/g.stats.pg/infxStats.c: fixed compile
	  problem on Debian
2003-08-25 08:53  markus
	* src.garden/grass.postgresql/g.column.pg/main.c: hopefully fixed
2003-08-25 08:49  markus
	* html/html/: d.rgb.html, r.composite.html: sync with HEAD
2003-08-25 08:48  markus
	* html/html/d.where.html: reverted wrong sync
2003-08-25 08:42  markus
	* src/tcltkgrass/module/d.barscale, html/html/d.barscale.html: sync
	  with HEAD
2003-08-25 08:33  markus
	* src/display/devices/PNGdriver/Gmakefile: sync with HEAD
2003-08-24 17:54  markus
	* NEWS.html: updated
2003-08-24 17:47  markus
	* src/display/d.barscale/cmd/main.c: fixed patch
2003-08-22 09:55  markus
	* src.garden/grass.postgresql/g.select.pg/main.c:
	  G_unsetenv(PG_HOST); fix sync'ed with HEAD
2003-08-20 15:28  markus
	* NEWS.html: updated, not yet complete - please add
2003-08-20 15:08  paul
	* src/raster/r.in.gdal/: Gmakefile, main.c: New proj-related
	  changes reverted
2003-08-20 14:29  markus
	* html/html/s.cellstats.html: added output of number of sites and
	  sum
2003-08-20 14:21  markus
	* html/sites.html: s.cellstats added
2003-08-20 14:17  markus
	* src/raster/r.fill.dir/ppupdate.c: Sync with HEAD
2003-08-20 14:13  markus
	* src/: raster/r.profile/cmd/main.c, mapdev/v.digit/node_lines.c:
	  Sync with HEAD
2003-08-20 14:10  markus
	* src/: ps.map/ps.map/cmd/do_labels.c,
	  ps.map/ps.map/cmd/ps_fclrtbl.c, ps.map/ps.map/cmd/ps_map.c,
	  ps.map/scripts/demo1.scr, ps.map/scripts/demo2.scr,
	  ps.map/scripts/demo3.scr, ps.map/scripts/demo5.scr,
	  ps.map/scripts/demo8.scr, ps.map/scripts/demo9.scr,
	  raster/r.transect/cmd/main.c: Sync with HEAD
2003-08-20 10:40  markus
	* src/raster/wildfire/src/r.spread/local_proto.h: Sync to release
	  branch
2003-08-20 10:35  markus
	* Makefile.in, NEWS.html,
	  src/imagery/i.ortho.photo/libes/Gmakefile,
	  src/mapdev/v.build/main.c, src/mapdev/v.digit/set_thresh.c,
	  src/mapdev/v.in.dgn/Gmakefile, src/mapdev/v.in.dgn/README,
	  src/mapdev/v.in.dgn/main.c, src/mapdev/v.in.mif/main.c,
	  src/mapdev/v.in.mif/write_lines.c, src/mapdev/v.in.shape/lines.c,
	  src/mapdev/v.in.shape/vmap_import.c,
	  src/mapdev/v.mkquads/ask_for.c,
	  src/mapdev/v.mkquads/calc_quads.c,
	  src/mapdev/v.out.e00/v.out.e00.c, src/mapdev/v.timestamp/main.c,
	  src/misc/m.in.e00/info.c, src/misc/m.kappa/cmd/main.c,
	  src/misc/m.kappa/cmd/prt_hdr.c,
	  src/misc/m.kappa/cmd/readin_data.c,
	  src/ps.map/devices/ps.devices/a3,
	  src/ps.map/devices/ps.devices/a4,
	  src/raster/r.colors/cmd/local_proto.h,
	  src/raster/r.colors/cmd/main.c, src/raster/r.colors/cmd/rules.c,
	  src/raster/r.cost/cmd/btree.c, src/raster/r.cost/cmd/main.c,
	  src/raster/r.cost/cmd/stash.h, src/raster/r.his/cmd/main.c,
	  src/raster/r.in.doq/cmd/get_newhead.c,
	  src/raster/r.in.gdal/Gmakefile,
	  src/raster/r.in.gdal/gbgetsymbol.c,
	  src/raster/r.in.gdal/gdalbridge.c,
	  src/raster/r.in.gdal/gdalbridge.h, src/raster/r.in.gdal/main.c,
	  src/raster/r.info/inter/main.c,
	  src/raster/r.info/inter/more_print.c,
	  src/raster/r.los/cmd/delete.c, src/raster/r.los/cmd/main.c,
	  src/raster/r.los/cmd/mark_pts.c, src/raster/r.los/cmd/pts_elim.c,
	  src/raster/r.mapcalc3/evaluate.c,
	  src/raster/r.mapcalc3/expression.c,
	  src/raster/r.patch/cmd/main.c, src/raster/r.patch/cmd/nfiles.h,
	  src/raster/r.reclass/cmd/reclass.c,
	  src/raster/r.timestamp/main.c,
	  src/raster/wildfire/src/r.ros/spot_dist.c,
	  src/raster/wildfire/src/r.spread/cell_ptrHa.h,
	  src/raster/wildfire/src/r.spread/cmd_line.h,
	  src/raster/wildfire/src/r.spread/collect_ori.c,
	  src/raster/wildfire/src/r.spread/costHa.h,
	  src/raster/wildfire/src/r.spread/deleteHa.c,
	  src/raster/wildfire/src/r.spread/display.c,
	  src/raster/wildfire/src/r.spread/fixHa.c,
	  src/raster/wildfire/src/r.spread/get_minHa.c,
	  src/raster/wildfire/src/r.spread/insert2Ha.c,
	  src/raster/wildfire/src/r.spread/insertHa.c,
	  src/raster/wildfire/src/r.spread/main.c,
	  src/raster/wildfire/src/r.spread/pick_dist.c,
	  src/raster/wildfire/src/r.spread/pick_ignite.c,
	  src/raster/wildfire/src/r.spread/ram2out.c,
	  src/raster/wildfire/src/r.spread/replaceHa.c,
	  src/raster/wildfire/src/r.spread/select_linksB.c,
	  src/raster/wildfire/src/r.spread/spot.c,
	  src/raster/wildfire/src/r.spread/spread.c,
	  src/scripts/contrib/d.rast.labels/d.rast.labels,
	  src/scripts/contrib/d.rast.leg/d.rast.leg,
	  src/scripts/contrib/grassmirrorsmap/grass.sites.main,
	  src/scripts/contrib/grassmirrorsmap/grass.sites.mirror,
	  src/scripts/contrib/grassmirrorsmap/grass_sites.gif,
	  src/scripts/contrib/grassmirrorsmap/grass_sites.htmlmap,
	  src/scripts/contrib/grassmirrorsmap/grassmap.html,
	  src/scripts/contrib/grassmirrorsmap/mkgrassmap.sh,
	  src/scripts/contrib/r.fillnulls/r.fillnulls,
	  src/scripts/contrib/r.to.pg/r.to.pg,
	  src/scripts/contrib/s.in.atkisdgm/s.in.atkisdgm,
	  src/scripts/contrib/s.in.atkisdgm/s.in.atkisktb,
	  src/scripts/contrib/s.in.garmin.sh/s.in.garmin.sh,
	  src/scripts/contrib/v.cutregion.sh/v.cutregion.sh,
	  src/scripts/contrib/v.in.garmin.sh/v.in.garmin.sh,
	  src/scripts/contrib/v.in.mapgen.sh/v.in.mapgen.sh,
	  src/scripts/contrib/v.line2area/v.area2line,
	  src/scripts/contrib/v.line2area/v.line2area,
	  src/scripts/contrib/v.region.sh/v.region.sh,
	  src/scripts/shells/slide.show.sh, src/sites/s.cellstats/main.c,
	  src/sites/s.cellstats/univar.c, src/sites/s.cellstats/univar.h,
	  src/sites/s.in.ascii/get_site.c, src/sites/s.in.ascii/main.c,
	  src/sites/s.in.dbf/main.c, src/sites/s.out.ascii/main.c,
	  src/sites/s.qcount/main.c, src/sites/s.qcount/tutorial/output,
	  src/sites/s.windavg/main.c, src/tcltkgrass/main/gis_set.tcl,
	  src/tcltkgrass/module/d.barscale, src/tcltkgrass/module/d.grid,
	  src/tcltkgrass/module/r.proj, src/tcltkgrass/module/r.transect,
	  tools/diff.sh: Sync to release branch
2003-08-20 09:53  markus
	* src/libes/gis/sleep.c: Sync to release branch
2003-08-20 09:47  markus
	* src/general/: init/Gmakefile, init/README, init/chk_dbase.c,
	  init/grass.src, init/grass_intro.txt, init/init.sh,
	  init/mke_loc.c, init/mke_mapset.c, init/set_data.c,
	  g.ask/cmd/main.c, g.filename/cmd/main.c, g.findfile/cmd/main.c,
	  g.gisenv/main.c: Sync to release branch
2003-08-20 09:35  markus
	* src/fonts/for_grass/splitfont.c,
	  src.garden/grass.postgresql/tutorial/index.html: Sync to release
	  branch
2003-08-20 09:31  markus
	* src/: display/d.leg.thin/main.c, display/d.what.sites/main.c,
	  fonts/fonts/cyrilc.hmp: Sync to release branch
2003-08-20 09:28  markus
	* src/display/: d.area/screenpoly.h,
	  devices/windows/libW11/w32/xlib.c, d.geodesic/cmd/Gmakefile: Sync
	  to release branch
2003-08-20 09:19  markus
	* src/CMD/: VERSION, lists/GRASS: Sync to release branch
2003-08-20 09:16  markus
	* src/: display/d.barscale/cmd/draw_scale.c,
	  display/d.barscale/cmd/main.c, display/d.barscale/cmd/mouse.c,
	  display/d.barscale/cmd/options.h, general/g.parser/test.sh: Sync
	  to release branch
2003-08-20 09:10  markus
	* aclocal.m4, documents/cygwin_grass50bininstall.html,
	  documents/release_rules.txt, documents/sites_format50.txt,
	  html/raster.html, html/sites.html, html/html/d.barscale.html,
	  html/html/d.colormode.html, html/html/d.colors.html,
	  html/html/d.colortable.html, html/html/d.rgb.html,
	  html/html/d.save.html, html/html/d.site.labels.html,
	  html/html/d.site.pg.html, html/html/d.sites.label.html,
	  html/html/d.where.html, html/html/r.fill.dir.html,
	  html/html/r.sun.html, html/html/s.in.ascii.html,
	  html/html/s.in.dbf.html, html/html/s.in.shape.html,
	  html/html/s.surf.idw.html, html/html/s.vol.rst.html,
	  html/html/s.voronoi.html, html/html/shade.rel.sh.html,
	  html/html/v.build.polylines.html, html/html/v.extract.html,
	  html/html/v.import.html, html/html/v.in.gshhs.html,
	  html/html/v.mkquads.html, html/html/v.spag.html: Sync to release
	  branch
2003-08-20 08:57  markus
	* src/scripts/shells/shade.rel.sh: Sync with HEAD
2003-08-08 16:41  paul
	* src/libes/proj/do_proj_nad.c: Bugfix to old datum shifting for
	  releasebranch
2003-07-10 08:24  markus
	* src/general/g.mapsets/main_cmd.c: fix typo bug: #2011
2003-07-04 09:35  markus
	* html/html/: g.findfile.html, r.cost.html, r.flow.html,
	  r.flowmd.html, r.in.ascii.html, r.in.poly.html, s.buffer.html,
	  s.kernel.html, v.bubble.html, v.circle.html: sync'ed with HEAD
2003-06-11 12:25  paul
	* src/raster/r.in.gdal/main.c: Important bugfix (for correct
	  PROJ_INFO files) added to release branch
2003-05-29 12:19  markus
	* src/sites/s.in.dbf/dump.c: buffer enlarged (bug #1891)
2003-05-08 15:16  markus
	* src/sites/s.out.e00/s.out.e00.c: sync with HEAD
2003-05-07 08:23  markus
	* src/raster/r.statistics/cmd/method.h: sync with HEAD
2003-05-06 17:23  markus
	* src/raster/r.topmodel/main.c: sync with HEAD
2003-05-06 15:50  markus
	* src/raster/: r.profile/cmd/main.c, r.quant/main.c: sync with HEAD
2003-05-06 15:37  markus
	* src/raster/r.tiff/r.out.tiff.c: sync with HEAD
2003-05-06 14:33  markus
	* src/raster/r.in.bin/main.c, html/html/r.info.html: sync with HEAD
2003-05-06 09:05  markus
	* src/raster/r.thin/cmd/size.c: sync with HEAD
2003-05-06 09:01  markus
	* src/raster/r.statistics/cmd/: median.c, method.h, moment.c,
	  skew.c: sync with head
2003-05-06 09:00  markus
	* src/raster/r.statistics/cmd/unused/: median.c, moment.c, skew.c:
	  sync with HEAD
2003-05-06 08:55  markus
	* src/raster/r.patch/cmd/: Gmakefile, patch.c: sync with HEAD
2003-05-06 08:52  markus
	* src/raster/wildfire/src/r.spread/prob_invsqr.c: moved to
	  prob_invsqr/ to avoid 5.1 conflict with two main()
2003-05-06 08:51  markus
	* src/raster/wildfire/src/r.spread/prob_invsqr/prob_invsqr.c: moved
	  here from ../ for 5.1
2003-05-06 08:37  markus
	* src/raster/r.los/cmd/newsegment.c: removed leftover file
2003-05-06 08:23  markus
	* src/raster/r.coin/cmd/: Gmakefile, cmd.c, cmd_parms.c: sync with
	  HEAD
2003-04-29 18:27  markus
	* src/display/d.barscale/cmd/main.c: sync'ed with HEAD
2003-04-24 09:51  markus
	* src.contrib/GMSL/NVIZ2.2/src/interface.h: added TK8.4 fix from
	  HEAD
2003-04-18 13:37  markus
	* src/general/g.parser/test.sh: sync with HEAD
2003-04-18 09:58  markus
	* html/html/r.colors.html: sync with HEAD
2003-04-16 09:01  markus
	* src/imagery/i.class/draw_match.c: sync with head
2003-04-11 15:05  radim
	* src/mapdev/v.to.db/parse.c: vector option
2003-04-11 08:35  markus
	* NEWS.html: fix
