[GRASS5] installing GRASS without fink
Michael Barton michael.barton at asu.edu
Sat Dec 13 11:28:11 EST 2003
On Saturday, December 13, 2003, at 12:01 PM,
grass5-request at grass.itc.it wrote:
> I don't like using fink unless I **have** to. Otherwise, I end up with
> multiple versions of applications and libraries, and conflicts between
> versions. For example, if I already have python2.3 on my system, I
> don't need fink installing another one. I have installed GRASS from
> cvs on my powerbook without any use of fink, so it is not necessary.
Chris,
How did you install tcltk? Did you install it from source or do you
have a place to find binaries? This is the only reason I **need** fink
for installing GRASS, though there are some other things it is quite
handy for.
Thanks.
Michael Barton
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
