[GRASS5] 57 with postgres on OSX
Markus Neteler neteler at itc.it
Tue Dec 16 07:26:52 EST 2003
On Mon, Dec 15, 2003 at 08:19:38PM +0000, Glynn Clements wrote:
> Kirk R. Wythers wrote:
> > Here is a compile error that I occurs when trying to build 57 (latest
> > snapshot) with postgresql on OSX (the build finished with no errors if
> > I simply remove the lines:
> >     --with-postgres-includes=/sw/include/postgresql \
> >     --with-postgres-libs=/sw/lib \
> > and add the line:
> >     --without-postgres \
> > to the config script.
> > I would very much like to be able to post 57 binaries with postgres
> > support, but I could use some feedback from more experienced builders
> > as to how to resolve this issue. In an earlier email Markus wrote:
> > "Your problem looks like a configure issue.
> > In ./db/drivers/postgres/Makefile
> > CRYPTLIB = -lcrypt
> > is hardcoded. Maybe this should go elsewhere into Platform.make
> > Markus"
> > Markus, Can you (or anyone else) expand on this idea? I just don't
> > follow.
> Just remove that line, or change it to an empty definition, i.e.:
> 	CRYPTLIB =
> If you get any "undefined symbol" errors as a result, tell us what
> they are.
is updated in CVS now.
Markus
