[GRASS5] [bug #1664] (grass) error during compilation of SG3d module
Glynn Clements glynn.clements at virgin.net
Wed Feb 19 11:58:37 EST 2003
Paul Kelly wrote:
> Changing GL/gl.h to gl/gl.h will also work (gl.h is a symlink to gl/gl.h),
Do you know which is the correct way to reference this header?
Glynn Clements <glynn.clements at virgin.net>
