[GRASS5] [bug #1561] (grass) tcl command error in tcltkgrass startup
Request Tracker grass-bugs at intevation.de
Fri Jan 31 18:52:49 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1561
Subject: tcl command error in tcltkgrass startup
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.2-cvs 20030131
Attempting to start Tcltkgrass:
GRASS:/arc/ddgray/cvs/main/grass > tcltkgrass&
[1] 16133
GRASS:/arc/ddgray/cvs/main/grass > bad switch "-dictionary": must be -ascii, -integer, -real, -increasing -decreasing, or -command
    while executing
"lsort -dictionary [split [read $fd] \n]"
    invoked from within
"foreach line [lsort -dictionary [split [read $fd] \n]]..."
    (procedure "set_list" line 25)
    invoked from within
"set_list etc ellipse.table 1 "\ \t""
    invoked from within
"set spheroids [set_list etc ellipse.table 1 "\ \t"]..."
    (file "/opt/grass5/tcltkgrass/main/gui.tcl" line 1776)
    invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
    invoked from within
"if [catch {source $env(TCLTKGRASSBASE)/main/gui.tcl}] {
    set env(TCLTKGRASSBASE) $env(GISBASE)/tcltkgrass
    source $env(TCLTKGRASSBASE)/main/gui. ..."
    (file "/opt/grass5/bin/tcltkgrass" line 26)
All home directory rc files had been cleared.
Problem occurred with 3 separate Tcl/Tk installations, most recent 8.3.3
(Mandrake 9.0)
I can't think of anything local that might be causing this. But I'm not
a Tcl expert.
DD Gray
-------------------------------------------- Managed by Request Tracker
