[GRASS5] r.in.gdal segmentation fault
Bernhard Reiter bernhard at intevation.de
Thu Jun 5 12:15:46 EDT 2003
On Thu, Jun 05, 2003 at 11:28:18AM -0400, Helena Mitasova wrote:
> I had a student install the latest GRASS binary release on RedHat9
> and r.in.gdal gave segmentation fault for a tiff file (it imported OK
> with r.in.tiff) - we will recompile from sources making sure that we
> have
> the latest GDAL, but does this mean the GDAL used in the binaries
> is the old version? Has anybody had a chance to try r.in.gdal in the
> binary release?
> Or is this specific for RedHat9? (BTW if anybody is running GRASS on
> RedHat8
> I suggest switching to RedHat9 - it is way much better).
It depends largely where the binaries have been build.
Some binaries _might_ be incompatible with never versions of redhat.
C++ applications and applications using old thread interfaces
might be affected.
To follow up this bug you probably should build GRASS and GDAL from
source for redhat 9.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030605/2ac00e00/attachment.bin
