[GRASS5] [bug #1923] (grass) Compilation error of
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Jun 5 14:55:42 EDT 2003
You need to use the CVS HEAD of GRASS 5.0, or at least the 5.0 snapshot
with the same date as (or as close as possible to) the 5.1 snapshot
On Thu, 5 Jun 2003, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1923
> Subject: Compilation error of
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> My name is jonathan Ghellere and that error occurs:
> make[2]: Entrando no diretório `/root/Grass5/grass51_exp_2003_05_31/lib/gis'
> gcc -g -O2  -Wall  -I/root/Grass5/grass51_exp_2003_05_31/include -I/root/Grass5/grass51_exp_2003_05_31/dist.i686-pc-linux-gnu/include      -I/root/Grass5/grass51_exp_2003_05_31/include -I/root/Grass5/grass51_exp_2003_05_31/dist.i686-pc-linux-gnu/include \
>         -o OBJ.i686-pc-linux-gnu/get_datum_name.o -c get_datum_name.c
> get_datum_name.c:33: conflicting types for `G_ask_datum_name'
> /root/Grass5/grass51_exp_2003_05_31/include/gisdefs.h:533: previous declaration
> of `G_ask_datum_name'
> /root/Grass5/grass51_exp_2003_05_31/include/gis.h:36: warning: `GRASS_copyright' defined but not used
> make[2]: ** [OBJ.i686-pc-linux-gnu/get_datum_name.o] Erro 1
> make[2]: Saindo do diretório `/root/Grass5/grass51_exp_2003_05_31/lib/gis'
> make[1]: ** [subdirs] Erro 1
> make[1]: Saindo do diretório `/root/Grass5/grass51_exp_2003_05_31/lib'
> make: ** [default] Erro 1
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
