[GRASS5] Compression (?) of CELL maps (int)
Glynn Clements glynn.clements at virgin.net
Fri Jun 6 08:16:02 EDT 2003
Bernhard Reiter wrote:
> > FWIW, I intend to completely re-write the raster I/O code once I move
> > to 5.1.
> Wouldn't be better to wait for 5.3 for this then?
Why? The changes would be substantially less far-reaching than the
5.1. vector re-write.
> > The existing code isn't particularly legible; two significant
> > bugs which were introduced with the addition of FP and NULL support
> > managed to remain undetected until after 5.0.0 was released.
> Is there a possibility to only fix the bugs first?
I've already fixed those two bugs; it was the process of doing so that
led me to the conclusion that the raster I/O code needs to be
re-written to improve legibility.
Glynn Clements <glynn.clements at virgin.net>
