[GRASS5] Fw: Use of LINZ grid file
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Jun 23 11:55:12 EDT 2003
On Mon, 23 Jun 2003, Bernhard Reiter wrote:
> Does the data come with all the the necessary freedoms
> for everybody to use, modify, adapt and publish it?
> We might need a public or written statement.
> The general statement below for the software does not
> explicitely allow redistribution. It would be better if they
> were using a known Free Software license (like X11 license in this case).
> The email about the license could be interpreted as
> that you (or we), but not everybody else gets that permission,
> it would be better of they stated the conditions more clearly
> in the distribution archive or on the website.
'It would be better........' but it's adequate the way it is, right?
Should we have a special text file in the directory where the grid shift
files are stored, explaining the licensing conditions for each one?
The USA and Canada files were added last year I think and probably they
also are provided under some similar free distribution terms.
Maybe someone can undertake to check this up and collect all the terms /
conditions into one file.
Paul
