[GRASS5] Update for Spearfish sample data
Markus Neteler neteler at itc.it
Fri May 9 12:12:58 EDT 2003
Dear developers,
based on help and suggestion from Paul Kelly I have
updated the PROJ_INFO file in the Spearfish sample data set.
The ellipsoid and datum was wrong (was WGS84, but it is Clarke66).
Paul suggested:
On Fri, May 09, 2003 at 05:01:35PM +0100, Paul Kelly wrote:
> Hello again Markus
> I think I have found a way of writing the PROJ_INFO so it is backward
> compatible; it relies on the fact that if GRASS doesn't recognise an
> option it will pass it on unaltered to PROJ so we just put the nadgrids
> datum parameter in at the end:
> proj: utm
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> f: 294.9786982000
> zone: 13
> nadgrids: conus
> This won't be exactly the standard way of writing a PROJ_INFO file but it
> will work and there is no problem with it so I think it should be fine to
> use it to avoid having different spearfish versions like you say.
> Paul
The updated package is here:
http://mpa.itc.it/markus/tmp/spearfish_grass50data.tar.gz
please
 - try with any 5.0.x
 - try on various platforms
You may simply run
 g.region -l
which uses PROJ4 to report the current region in Lat/Long coordinates.
If reports are ok, I'll move the file to
 http://grass.itc.it/data.html
Thanks,
(especially to Paul)
 Markus
