[GRASS5] ps.map grid lines hidden under vector areas
H Bowman hamish_nospam at yahoo.com
Tue May 13 04:09:55 EDT 2003
Hi -
Is there any reason why ps.map draws grid lines before unmasked vector areas?
makes the output look funny..
from src/ps.map/ps.map/cmd/ps_map.c:
    /* do the masked vector plots, if any */
    if (vector.count) do_vectors(0);
    /* do the masked ponts/lines, if any */
    do_plfile(0);
    /* do masking, if required */
    PS_make_mask();
    if (PS.mask_needed)
        do_masking();
    /* do the grid, if any */
    do_grid();
    /* do the unmasked vector plots, if any */
    if (vector.count) do_vectors(1);
    /* do the sites, if any */
    do_sites();
    /* do the grid numbers, if any */
    if (PS.grid_numbers > 0) do_grid_numbers();
Shouldn't the grid lines come just before the grid numbers?
ta,
Hamish
