[GRASS5] g51: r.coin compile error
Stephan Holl sholl at gmx.net
Thu May 22 05:44:53 EDT 2003
At Thu, 22 May 2003 10:05:37 +0100 (BST) Paul Kelly wrote:
Hello Paul, Markus
> >  cd grass51/
> >  make mix
> >  cd src/raster/r.coin/
> >  -> check that cmd.c is not there but cmd_parms.c
> I had a problem with 'cvs update -dP' not removing old files and it
> was causing GRASS 5.1 compilation problems (you may remember from a
> few weeks ago). I had to use the -A flag, i.e. 'cvs update -dPA'. This
> forcibly updated to the latest HEAD. Might be useful.
that was the same problem I was struggeling with. after cvs up -dP
everything "seems" to be up-to-date, but it wasn't.
Markus second hint solved this, but the A-flag during CVS-Update is
worth a try.
Thank you both, now it compiles clean.
cheers
  Stephan
Stephan Holl
GnuPG Key-ID: 11946A09
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030522/8740b242/attachment.bin
