[GRASS5] Some CVS commit statistics
Bernhard Reiter bernhard at intevation.de
Thu Nov 6 05:56:05 EST 2003
On Thu, Nov 06, 2003 at 02:15:16AM +0100, Markus Neteler wrote:
> FYI - here some CVS commit statistics. Of course commits are
> not the best measure, maybe someone could do an analysis
> based on changed lines of code?
Even the changed lines of code only have a limited meaning.
Sometimes it takes very long to change just one line
and the other way round.
Anyway those number do have some value.
It clearly shows that Markus is leading the pack by a far measure!
It is time again to say
	THANKS Markus for the great work on GRASS!
Also we could use more developers as always.
The number has not significantly increased with some people
dropping out and some joining in.
It seems that some developers move activities from 5.0/5.3 towards 5.7
over time. This seems to be a good sign.
Regarding web commits, we gained one active person,
but also could use more here.
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031106/3a48b23e/attachment.bin
