[GRASS5] r.contour question
Michael Barton michael.barton at asu.edu
Fri Nov 21 04:21:53 EST 2003
This is a simple question, but it is not mentioned in the manual
Does r.contour only produce integer output, even if the raster map is
floating point?
That is the only way I can explain some funny results  I got when
trying a demo contour map. The contour map looks fine, but the values
do not. There are duplicate values on some adjacent lines and only
integers show up in the cat values.
Thanks.
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
