[GRASS5] [bug #2233] (grass) problem with NVIZ on Suse 9.0
Request Tracker grass-bugs at intevation.de
Fri Nov 21 08:25:51 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2233
Subject: problem with NVIZ on Suse 9.0
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.3 final release
  I compiled myself the source code (of grass 5.0.3-final) and used a script from Markus Neteler to build binaries for GRASS 5.0.3 (and get the code from CVS). The binaries was compiled with:
System:
i686-pc-linux-gnu, compiled with:
Including precompiled  library for r.in.gdal
Configured with: ../configure --enable-threads=posix --prefix=/usr --with-local-prefix=/usr/local --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib --enable-languages=c,c++,f77,objc,java,ada --disable-checking --enable-libgcj --with-gxx-include-dir=/usr/include/g++ --with-slibdir=/lib --with-system-zlib --enable-shared --enable-__cxa_atexit i586-suse-linux
Thread model: posix
gcc version 3.3.1 (SuSE Linux)
  I also have to use a "--without-motif" because I was unable to find motif on my machine. I also used g.dal version 1.1.9.
  Anyway, I have tested it (the binary and the compiled in two computers with Suse 9.0) and found a bug on NVIZ every time that I use the perspective, height and zexag sliders. The log of this error is below:
can't read "Priv(.top2.panelarea.panels.main.midf.height.scale,relief)": no such element in array
   while executing
"$w configure -sliderrelief $Priv($w,relief)"
   (procedure "tk::ScaleEndDrag" line 4)
   invoked from within
"tk::ScaleEndDrag .top2.panelarea.panels.main.midf.height.scale"
   (command bound to event)
   This bug doesnt crash NVIZ, but it can show up every time that I used the sliders.
   I'm using Suse 9.0, that uses Tcl and Tk 8.4. My machine is a Athlon XP 2200, with 512 Mb RAM.
   Thank you for your time.
   Bye.
Oceanographer Christian dos Santos Ferreira
Lab. of Fisheries Reaserch and Hydroacoustics
Departament of Oceanography
Federal University of Rio Grande (FURG)
Av. Italia km 8 s/n - Campus Carreiros
Caixa Postal 474 - CEP 96203-000
Rio Grande - RS - Brazil
Phone: (53) 233-6528 - Fax: (53) 233-6601
"Open source:...
        ...Millions of open minds can't be wrong."
-------------------------------------------- Managed by Request Tracker
